New radiator
Old Mar 19, 2011 | 01:43 AM
native1031's Avatar
New radiator
Replacing the radiator in my 84.
First, is there anything else I should use in the new radiator to help prevent corrosion and rust?
Second, I want to use distilled water when I install the new radiator so I can flush a couple times at home. Then ill use actual coolant.
Is that a good idea^?
Old Mar 19, 2011 | 12:18 PM
native1031's Avatar
Re: New radiator
Edited my post instead of creating a new one. Want to do this swap today
Old Mar 19, 2011 | 12:24 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: New radiator
50/50 mix of water and coolant is all that's needed. No need to flush a new radiator, it's new. Corrosion is going to happen, regardless - it's the nature of the beast. You can used distilled water, it will help. But one day, sooner or later, you'll be 300 miles from home, and a hose will crap out - you'll end up dumping in tap water anyway.
Look at it this way ... my 1992 had the factory radiator - nothing wrong with it - so it was 15 years old when I poked a hole in it and had to replace it. What else can be so easily changed, lasts 15+ years with tap water, and costs less than $100? I say fill it with tap water and coolant 50/50 and be done.
Old Mar 19, 2011 | 12:33 PM
native1031's Avatar
Re: New radiator
what about the coolant in the engine? Instead of using a hose or "flush" kit I was thinking of just running distilled water and then drain/refill a couple times before putting coolant. I just want to get as much of the crap out as possible.
native1031's Avatar
Re: New radiator
How much coolant would I possibly need to fill a radiator?
Old Mar 19, 2011 | 12:44 PM
Car: 1992 RS
Engine: Carbed 350
Re: New radiator
Buy 2 gallons - won't need it all, but need more than 1 probably.
90% of the engine coolant will drain when you remove lower radiator hose. Can remove coil wire and run the starter for a minute, will force water pump to turn and pull out some more.
Old Mar 19, 2011 | 12:46 PM
native1031's Avatar
Re: New radiator
You've helped me quite a bit on this cite. Thanks
sheachopper
Jul 31, 2019 11:27 AM
lanceflame44
Sep 25, 2015 12:28 PM
