coolant disappearing from radiator
Old Mar 27, 2011 | 10:34 AM
chrisfrerick's Avatar
I have 1988 iroc camaro 350 and about every two days the coolant is gone from radiator. coolant is still in the bottle and that never changes. I did a pressure test of coolant system and at first I found a leak in a hose for coolant to throttle body. I fixed that but it still is using coolant but never pulls from the bottle. there is no smoke coming from exhaust and there's no coolant in oil. any ideas?
Old Mar 29, 2011 | 02:44 PM
Guest
Guest
Posts: n/a
Re: coolant disappearing from radiator
coolant theives?
Old Mar 31, 2011 | 03:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Did you change the cap?
Old Mar 31, 2011 | 03:59 PM
rs89todd's Avatar
Car: 1986 Chevrolet Camaro
Engine: 355 chevy
Transmission: t-5
Axle/Gears: 3.73 disc brakes
Heater core?
Old Mar 31, 2011 | 04:18 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
water pumps gone bad
Old Mar 31, 2011 | 04:22 PM
dustinxix's Avatar
Car: 1988 firebird formula
Engine: 5.7 TPI :)
Transmission: Auto :(
Axle/Gears: 9 bolt LSD
headgasket :P
Old Mar 31, 2011 | 04:25 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not likely to be any of those if it holds a pressure test.
Old Jun 17, 2011 | 07:06 PM
caps been change as well
Old Jun 17, 2011 | 07:26 PM
RyanEricW's Avatar
You need to do a cylinder leak down test for each cylinder. While doing so, check for bubbles in your radiator...
Wait is this an auto? Perhaps trans/coolant jackets are crossing....? I doubt it, but still the chance.
Old Jun 23, 2011 | 12:19 PM
Guest
Guest
Posts: n/a
mushroom cap looken thing next to the TB.
Old Jun 23, 2011 | 01:34 PM
Dark Ember's Avatar
Car: 90' Firebird Formula 350
Can we get a little bit more on diagnostics? Is there coolant residue anywhere in the engine bay, like near the radiator cap?
Does the car actually leak, or at least leave puddles of coolant once you park it?
Old Jun 23, 2011 | 01:36 PM
joee5's Avatar
Car: 1986 Z28, 2006 Cadillac Escalade
Engine: 5.0 litre
May be losing it through your exhaust. Just happened to me few months back with my Malibu.
Old Jun 23, 2011 | 01:53 PM
RyanEricW's Avatar
Instead of guessing around with heads in ***, try this.
Listen for air leaking from tailpipe, from radiator (bubbles), intake, etc.
Old Jun 23, 2011 | 04:47 PM
NeoTath's Avatar
Car: 1987 Firebird Formula 350
Transmission: 700-R4
my old car i use to have blew a head gasket and it sucked the coolant in the heads and evaporated through my exhaust. lol ran for like a year with a blown head gasket till it died on the way to the scrap yard.
Old Jun 23, 2011 | 06:34 PM
joee5's Avatar
Engine: 5.0 litre
Lucky you. Mine lasted 2 weeks started dyin on my way back home from Six Flags with me kids.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
