How many screws hold the heater box?
Old Apr 7, 2011 | 04:08 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
I see two if them at the bottom, but it sure feels like there's more holding it in there than those two screws. I see one that almost looks like it comes in from the firewall.
I'm trying to change my heater box because the lever that controls the door is broke off. I already have the dash pulled about halfway back.
Old Apr 7, 2011 | 04:15 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Re: How many screws hold the heater box?
I can tell you that one is a PITA to get to. I believe there is four total, but the one at the top of the case behind the dash is a real pain. The previous owner just broke the thing off on mine.... Try not to do that on yours, as heat flow to the dash vents will suck. Get a small flashlight and see if you can find the other(s).
Old Apr 7, 2011 | 08:23 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
I'll have to look closer the next day I get a chance to mess with it. Even with the dash pulled back it's still hard to get to, sure is a lot of trouble just for a broken lever.
Old May 8, 2011 | 11:07 AM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
there is 4 under the hood, four inside the car. All 10mm bolts. be sure to remove the drier (silver cylinder in front of box) before pulling the assembly out.
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
86CamaroDan
Sep 29, 2015 10:08 PM
billybob6110
Sep 23, 2015 01:30 PM
greenyone
Aug 29, 2015 11:08 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
