Switching from one big fan to duels
Old Apr 30, 2011 | 03:45 PM
scaggsj's Avatar
Car: 1991 Camaro RS
Engine: 3.1L
Axle/Gears: Stock
Hello,
Heres my setup, 3.1L stock v6 no mods yet.
Ok that being said I just put in a new 2 row radiator because the guy I bought it off of put stop leak in it and it was clogged and Id rather have a new one then try to flush. I flushed the rest of the system out but thats not the issue. I am going from one big fan to two 12" fans. I have to figure out how to mount them but I ran into a problem first. The fan was wired direct to power. I want mine to run with the switch. Where are they and how should I wire these up. I think I would like one to run with primary and one secondary but since it came stock with one big fan it probley dosent have secondary. So again any help you guys can give me will be greatly appreciated.
Old Apr 30, 2011 | 10:13 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Switching from one big fan to duels
Buy an aftermarket fan controller and use it - I highly recommend Flex-a-lite. The stock wiring, relays, and fan switches in the head are just junk in my opinion. The aftermarket controllers probe the radiator fins, and work so so much better than the factory junk.
Old May 1, 2011 | 06:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might read Willie's sticky at the top of the page for interesting info.
JamesC
Old May 1, 2011 | 01:16 PM
scaggsj's Avatar
Car: 1991 Camaro RS
Engine: 3.1L
Axle/Gears: Stock
Thank you, I dont know why I didnt think about aftermarket products. I guess I useally try to stick to oem products. I will definitly check into.
krisner89
Oct 10, 2015 06:03 AM
Slush92RS
Sep 2, 2015 08:56 PM
Ducati900ss
Sep 2, 2015 09:05 AM
downsouthboy
Aug 29, 2015 11:29 AM
TA8487
Aug 16, 2015 12:21 PM
