ac compressor
Old May 7, 2011 | 02:47 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
ac compressor
i have a 91 camaro v6, my ac compressor was cracked so im takin a risk and bought one from a junk yard. still had pressure when i cracked the lines so good sign there, but the compressor i pulled from my car has a electrical connection on the back and the one i pulled from the junk yard does not. just a plug kinda thing, do i need to swap it and if so how do i do that? or can it work without it
Old May 8, 2011 | 12:27 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: ac compressor
That's the high pressure cut out switch. To remove the one from your old compressor, you'll need a snap ring tool. (Need to look closely to see it)
The junkyard one I'm assuming should be the same way.
Old Feb 11, 2013 | 02:10 PM
RockShowTrader's Avatar
Car: 1988 GTA
Re: ac compressor
Needle nose pliers work on that ring as well, although it's not as graceful a removal - mine almost flew away when it popped out - but it works.
Galaxie500XL
Feb 1, 2020 04:53 AM
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
