Radiator Hose Rerouting
Old Jun 11, 2011 | 12:26 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
I was trying to get some info to see if the way I rerouted my hoses was OK, or would I run into any issues.
The car is an 85 Camaro Z28 that has the 89 350 TPI in it.
What I did to clean up the engine bay a bit was, I deleted all of the heater core hoses and the diverter valve on the passenger side. ALL I have running to the radiator is the main upper and lower hoses, and the Tranny cooler lines and the overflow hose. I plugged the intake manifold nipple and the throttle body nipples.
Will I run into any engine damaging issues with this setup?
Old Jun 11, 2011 | 07:29 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
Re: Radiator Hose Rerouting
noone?
Old Jun 11, 2011 | 07:59 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
With no bypass you'll have hot spots in the engine until the thermostat opens.
Old Jun 11, 2011 | 09:52 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
Hmm, so I would assume that I either need to drill a hole in the thermostat or reattach the hose from the radiator to the front of the intake manifold?
Old Jun 13, 2011 | 02:08 AM
BK5Murray's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Transmission: 700r4 auto
Axle/Gears: 3.73 posi
Instead of drilling a hole in the stat, you could try running it without one. Or put in a 160 and make it so the stat opens at a lower temp. That way there is less of a chance of overheating.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
