Heater core info and pos mechanical control needed
Old Jun 13, 2011 | 02:41 PM
Spinum's Avatar
I dropped a 1969 corvette zz383 in. I have a 91 convert T5 etc (lil built).The car is or was a AC equipt car (just dropped in) I want to del the A/C heater assembly and just go direct.Prob 1 I have 3 main core line values your basic 2 heater core lines and the main line to radiator from car .Can I del everything AC and heater core wise and and just run my water pump main and intake main direct to the core (is there a directional gate valve on stock core) and can I also cap off the Radiator main input nipple.like I would on a gen 2 ?Can I also find a mechanical control line and plate (from what years) and use the existing vac box and install ? Will I get a EMM (crash code) with the del and blow airbag as it has a 3rd wire Ive never seen before to airbag (I am thinking its a antijack blowout del)Saw the wire in the schematics when I put in the viper system under dash? Whats my best route if anyone can help ? I may order wet jetted pulleys but for now we glass beaded the factory assembly so AC is in tact and pretty.I want it all gone though.Can I pull it all- run a gen 1 belt config-run 2 lines for core-del a/c and fnd control set easy?It must go back on road now so any help would be a godsend right now.kinda asap (got 2 bay area tied up due to its a quick drop and go)
Casey Meyers
Mar 2, 2016 10:46 AM
IROCZ1989
Jan 24, 2016 03:55 PM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
