Need help with Fan switch wiring! :)
Old Jun 18, 2011 | 10:27 AM
Lukaz's Avatar
Hey guys,
I believe this is the right section for this; I've purchased a 1984 camaro z28 305 h0 awhile back, and since then started repairing all the problems with the car. Recently i found out a problem with my cooling fan, that i believe that the wire for the fan switch was cut, so as many other wires. So the guy who owned the car before me, manually installed a switch inside the dashboard because of the situation. So now my question is; can somebody sell me a wiring harness, or direct me to some sites that sell wiring harnesses for the engine bay?
Thanks Lukaz
Old Jun 18, 2011 | 03:03 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Need help with Fan switch wiring! :)
Install an aftermarket fan controller. The factory type fan switch in the pass head never works well, and is junk in my opinion. Since you need to rewire it anyway, do it right and use an aftermarket controller like a Flex-a-lite. I run the $100 Flex-a-lite controller and it's great! Fully adjustable, doesn't use any factory wiring at all, and after 4 years, I wouldn't trade it for anything!
Old Jun 18, 2011 | 04:48 PM
one92rs's Avatar
Car: SOLD!!!!!
i think you like the flex controller a little more than i do. but it does work with zero problems.
Old Jun 19, 2011 | 12:04 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I'm starting to think he works for Flex-a-lite...
Old Jun 19, 2011 | 01:18 PM
luvmy64's Avatar
Dakota Digital also makes a nice one....
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
TA8487
Aug 16, 2015 12:21 PM
