Aftermarket heater core reccomendations?
Old Jun 25, 2011 | 12:33 AM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
In looking for a replacement heater core I see Spectra, Proliance, and Vista Pro as the three listed most often. Is there any difference in quality? Also, are the aftermarket cores made of brass or aluminum? I asume the OEM was brass. Thanks
Old Jun 25, 2011 | 09:40 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Aftermarket heater core reccomendations?
Never put any thought into a heater core - just grabbed one at local parts store. I'm not sure paying more for any name here will get you anything other than a lighter wallet - they work when they work, and they leak when they leak. It all boils down (no pun intended) to someone's bad day at work and not soldering a joint correctly.
Old Jul 1, 2011 | 11:02 PM
oldschool's Avatar
Engine: 2.8 LB8 HO
Did a little extra searching and found a GM nos core. I want to avoid the imported aluminum junk as long as I can.
Old Jul 2, 2011 | 12:16 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
i got an alum one from rock auto, its not an exact replacement but it works with a mod on the mounting.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
