86 Iroc Radiator Flush.
Old Jun 27, 2011 | 04:23 PM
R/T-Z28's Avatar
I have an 86 Iroc z with the 305 TPI. I bought a radiator flush kit but I cant seem to identify the heat inlet hose. I only see one that runs from the rad to some where the fire wall. The other only one that runs to the front of the engine is the large hose that connects to the thermo.
Any help would be appreciated.
Here is a pic. Is the hose connected to port 60 the one I need to splice and connect the waterhose to
Old Jun 27, 2011 | 05:16 PM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
Re: 86 Iroc Radiator Flush.
port 60 and 61 are the heater core hoses.
Old Jun 27, 2011 | 07:56 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Hose #62 that connects to port 60 is the heater inlet hose. Taking out connector #67 will eliminate the need to splice into anything if you can fit the T fitting in there.
1992 Trans Am
May 10, 2023 07:19 PM
Ron U.S.M.C.
Sep 7, 2015 08:38 AM
Clean87TA
Sep 4, 2015 11:23 PM
mustangman65_79
Aug 11, 2015 03:17 PM
