Coolant Testers ?
Old Jul 1, 2011 | 11:35 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Coolant Testers ?
I have two coolant testers. One is a tube that has little ***** in it. It measures in Fahrenheit and has temps marked on the side measuring the boiling point temps. From +215*F to +228*F.
The other is flat with a red arrow that moves up and down . It measures from 255*F to 268*F. And it says 15lb.cap on the side.
What temperature am I looking for with these testers in order to have a 50/50 mix ?
(or maybe 70/30 if suggested. )
Old Jul 1, 2011 | 11:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Coolant Testers ?
Don't worry about it, as long as it shows you an acceptable temperature.
Old Jul 2, 2011 | 12:17 AM
Engine: TBI,5.0
Thanks, but I'm kind of a nut when it comes to the car and like to be in control of even the smallest thing,so if you had to pick a temp on the gage what would you recommend and about what ratio of mix would that be?
Old Jul 2, 2011 | 12:41 AM
Engine: TBI,5.0
I did allot more searching and found this =
Examples of coolant mixtures:
Antifreeze Water Freezing Point Boiling Point(with 15lb radiator cap)
50% 50% -34 degrees F 265 degrees F
60% 40% -62 degrees F 269 degrees F
70% 30% -84 degrees F 276 degrees F
It says with a 15lb cap and I'm running the 16lb. I wonder how much of a difference that makes if any ?
Old Jul 2, 2011 | 12:46 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The ratio isn't the point, the boiling temperature is. We mix ratios so we know we have a minimum boiling point without having to measure with a hydrometer. You have the hydrometer, so you can just measure.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
