Heater fan resistors??
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
OK i understand that resistors are what controls the heater controls on the low and medium blower settings but where are these things at in the car??? Right now im stuck with high only for the heater blower... thanks for any help... i did try the search on here but found no info... thanks!!!!
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Heater fan resistors??
the resitors packs are part of the fan controls. ive got a diagram in a manual at home that shows the location. ill post that up when i get home.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
On the actual heater box attached to the firewall in the engine bay, you'll see a connector with 3 wires that attaches right to the box itself - two screws hold the box side of the connector in the box, remove those screws, and pull it out. There are coil(s) inside - those coils are the resistors. It's not "resistors" like you can get at Radio Shack.
Car: 1991 Camaro RS
ok i took out my air conditioning because it was junk and when i did this i made my own delete and i know what coils your talking about now... there are three right? different sizes?? They are on the upper part of the heater box on a car equipted with AC right??? Illfix it now since i know why they dont work since i took them out...opps... thanks for the help!!!!
Car: 91 Camaro RS
thats them. one is for low, and then the 2 med speeds
Car: 1991 Camaro RS
ok thanks... i got it working right!!!!!
