cooling fans
Old Jul 4, 2011 | 02:16 PM
laynlowz's Avatar
Car: 85 camaro
cooling fans
I am currently looking into cooling fans and was wondering what to go with. whats everyone running for cooling fans?
do I need dual fans or would a singal just be fine?
I got a 305 v8 and am still just running the clutch fan.
I would like to switch to a 350 someday.
Old Jul 4, 2011 | 07:03 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: cooling fans
single fan would be fine. even your clutch fan is fine (assuming it's working properly and shrouded properly. There is actuially very little with the fan itself that affects cooling - I'm running a 350 that runs warm, but using a single electric stock TBI fan and no problems.
The problems arise with the stupid GM factory fan switches, which are all junk - even the aftermarket $100 fan switches are junk. Use an aftermarket fan controller like a Flex-a-lite, with adjustable settings, and you will never go wrong. I have the $100 Flex-a-lite unit from Summit, it's been perfectly flawless now for 5+ years and keeps my car at 200 max no matter what the conditions (with a 180 stat).
Old Jul 5, 2011 | 03:16 PM
laynlowz's Avatar
Car: 85 camaro
Re: cooling fans
alright thanks
ya mine isnt shrouded that good. when I bought the car it only came with the top shroud I tried rigging up a bottom one off an old 1500 truck but its pretty crappy looking and now the fan seems to be hitting it.
Old Jul 5, 2011 | 03:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: cooling fans
There was no bottom shroud on your car originally, just the top.
I still run the clutch fan on my 84.
Old Jul 5, 2011 | 03:31 PM
laynlowz's Avatar
Car: 85 camaro
Re: cooling fans
oh really? guess that explains why i never seen any at the wreckers lol
I just find in town it gets to the red zone on my tempature gauge so I wanted to try to keep it abit cooler
Old Jul 5, 2011 | 10:25 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: cooling fans
edit.. wrong place
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
