lower hose sucking shut.
Old Jul 7, 2011 | 04:18 PM
84transamdude's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
On my old 383 when i rev up the motor the lower hose would start to suck close. Not the whole way. When driving motor temps would be around 200 when idle it would go up to 220. Replaced the rad. cap and seemed to improve a little. One guy tells me i need a hose with a spring in it and another tells me i have a pressure problem.
what do you guys think.
Old Jul 7, 2011 | 04:35 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: lower hose sucking shut.
Need a spring in it. Either yours is worn out or the hose is just so old that it cannot retain its shape.
I'd replace the hose.
Old Jul 7, 2011 | 04:57 PM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Ok so your saying I need a spring in it. do i buy it and put it in. I went to three different auto stores plus the dealer and they do not sell a hose with the spring in.
Old Jul 7, 2011 | 06:15 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Yep - the lower hoses have a spring in them to keep from collapsing - any spring that fits into the hose and just barely fits inside will work. They use a spring so it flexes with the bend.
Old Jul 10, 2011 | 07:24 PM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
ok sounds good. dumb question thou where do i get this spring at.
Old Jul 10, 2011 | 08:07 PM
Car: GTA
A new hose from a parts store should already have it in there. Never seen a separate spring you can buy for a hose. New hose time?
Bubbajones_ya
Jul 6, 2024 08:32 PM
tommy z-28
Oct 6, 2015 10:58 PM
Stryker412
Sep 20, 2015 06:59 PM
///DAN///
Brakes
Sep 17, 2015 07:43 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
