Hard Wire Fan >> Help
Old Jul 12, 2011 | 08:36 PM
Kozusnik's Avatar
Car: 1986 Sport Coupe Camaro
Engine: V6 2.8L vin S 173ci - MFI GAS
Transmission: 5 Speed Manual
Ok so I am looking to see if anyone else has hard wired there fan to a kill switch? The other day I was trying to fig out my cooling problem and its the fan it works when hooked straight to the battery but not when its hooked up normal... So I am just going to wire it to a kill switch but wanted some in put from those who have done this...
Old Jul 13, 2011 | 03:33 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Hard Wire Fan >> Help
if you want to control it manually, take the wire that normally goes to the switch in the head and wire it up to a switch that gets grounded when turned on. did this for a while on my last car without issue
Old Jul 13, 2011 | 03:36 PM
Kozusnik's Avatar
Thanks man got it done today seems to work well installed a in line fuse between the switch and the power source.
Old Jul 13, 2011 | 07:18 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I always had trouble with the factory fan setup - I always got a bad relay, or a bad fan switch. I went with an aftermarket fan controller than probes the radiator, and never looked back - 5 years later it's been perfect since day 1. The one I got was expensive ( Flex-a-lite @ $100), but is fully adjustable temp settings, has all the features you'd ever need, and comes with great directions and everything needed (does not use any factory wiring except the fan power and ground).
Old Jul 13, 2011 | 07:27 PM
chevysquid's Avatar
Car: 1986 IROC T-TOP
Transmission: 700-R4
make sure you have a relay in there or that wiring stands a good chance of melting.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
apie2546
Aug 8, 2015 07:12 AM
