making heat blow hot in winter
Old Jul 12, 2011 | 09:01 PM
JAMES LOWE's Avatar
Car: 84 Z28 camaro
Engine: 383 stroker
Transmission: turbo 350
My 84 camaro has a 383 in it with an aluminum radiator. During winter time when i turn the heat on it want get real warm. It has a 160 stat in it, when im sitting still its kinda warm but once driving it seems cool. Do i need to put a bigger stat in it during winter or is there something else i can do?
Old Jul 13, 2011 | 06:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: making heat blow hot in winter
Originally Posted by JAMES LOWE
Do i need to put a bigger stat in it during winter ....
Yes.
JamesC
Old Jul 13, 2011 | 07:05 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Flushing the heater core can also help a lot.
What is the engine temperature usually running at?
Old Jul 13, 2011 | 08:35 PM
JAMES LOWE's Avatar
Car: 84 Z28 camaro
Engine: 383 stroker
The engine normally runs between 180-190, so would a 180 or 195 stat be good?
Old Jul 13, 2011 | 08:36 PM
JAMES LOWE's Avatar
Car: 84 Z28 camaro
Engine: 383 stroker
Thats in summer time mind you, in winter bout 170
Old Jul 13, 2011 | 08:56 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
I drive year round. 180° stat is plenty good for winter.
If you had Minnesota type winters, then I would recommend the 195° stat. But for just near/at freezing temps, the 180 will do the trick.
Old Jul 13, 2011 | 11:49 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
that deffinately could be a problem. heater core could be slightly plugged also
Ghettobird52
Jul 5, 2024 11:18 PM
TheExaminer
Aug 26, 2015 04:59 PM
86IROC112
Aug 21, 2015 07:20 PM
86White_T/A305
Aug 17, 2015 12:16 AM
jackhammer
Aug 15, 2015 10:04 PM
