cooling fans still not working
Old Jul 14, 2011 | 08:33 PM
m smith's Avatar
I have ran every test I can think of and every thing checks out.I even checked the wires from the ecm to the relays and everything looks fine.I even replaced the ecm and still no fans.Put a scanner on it and fan request said yes and still no fans.I rigged up switches to ground each fan and throwing the switch seems to be the only way to get them to turn on.They both worked at one time then they both stopped working at the same time.Any ideas.Thanks
Old Jul 14, 2011 | 09:23 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: cooling fans still not working
During fan request, did you check for continuity on the ground from the ECM to the relay ?
Considering one is to use a crystal ball to know the vehicle you're talking about, that's the best guess I have.
Old Jul 14, 2011 | 10:42 PM
m smith's Avatar
1988 iroc 5.7L with dual cooling fans.I disconnected the relay and grounded the green white wire at the connector then disconnected the harness at the computer then hooked up a test light to power and checked terminal C1 on the computer end and the tester lit up so it looks like there is continuity
eightsixseven
Dec 16, 2024 01:50 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TheExaminer
Aug 26, 2015 04:59 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
