antifreeze
Old Jul 17, 2011 | 08:14 AM
jcrob's Avatar
antifreeze
hey guys any suggestions on what antifreeze i should get i have a 1990 rs with a 3.1L V6 MPI
and will this help my car from overheating? thanks
junior.
Old Jul 17, 2011 | 08:23 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: antifreeze
If your running straight water now, antifreeze won't help any overheating problem. So you need to find out why the car is overheating. Fans working? Air dam in place? Timing set correctly? Water pump working?
But also - if you don't have any antifreeze now, you need it! It keeps the insides from rusting. Even though straight water is generally cooler, it's not good for an engine/waterpump - straight water rusts, and has no lubricating properties for the water pump.
Standard old green antifreeze, mixed 50/50 with water, is optimal. No "brand names" are any better than any other "non-brands" - it's all the same chemical.
Old Jul 17, 2011 | 08:28 AM
jcrob's Avatar
Re: antifreeze
i know this is going to sound like a stupid question but how would i go about checking these things? I'm only 17 with limited tools so if you can let me know what tools i will need to check this thanks alot
junior.
Old Jul 17, 2011 | 09:51 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: antifreeze
I like 50/50 green with water wetter. Don't go swapping stuff in just yet though.
Visually check air dam. Black plastic wedge under the radiator. If it's missing or broken replace it.
Visually check the fans are working. They should be running once the car is hot or the ac is on. If not you will need a multimeter/voltimeter to check for power. If it has power verify connections look clean. If it doesn't try jumping them with extra wire to the battery or swapping the relay around to see if it works. Sometimes when you check the relay on the connection side its burnt meaning its arcing. Relays should be on the driverside firewall.
Replace the radiator cap. No tools needed.
Replace thermostat. You'll need housing gasket and some wrenchs, towel, and some coolant to top off with. They can fail shut, open, or etc. A good thermostat should allow the motor to warm up to rated temp on the thermostat then open allowing coolant to circulate and the temp should drop.
Visually check your upper and lower radiator hoses look good (no cracks, not pinched shut).
bryan623
Sep 19, 2015 10:13 AM
LastHopeRS
Jun 9, 2001 06:00 PM
Ward
May 31, 2001 12:12 PM
F_Bird89
Dec 13, 2000 11:05 PM
BAD Z-28
Dec 8, 2000 08:19 PM
