Fail Safety?
Old Jul 22, 2011 | 02:52 PM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
Fail Safety?
So I redone the top end of my motor and since then when I drive the car for 10+ mins then turn off the car and go to start the fan turns on, even when the key is turned to have the radio on. The temp guage on my car shoots up when i start it but when tap it to loosen up go straight down and might work im not sure. Anyways, I was wondering if GM offered a "Fail Safety" for your fans to turn on when the car cannot read its temp
Old Jul 22, 2011 | 03:16 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Fail Safety?
You mean run the fan while the car is stopped? There's no point. If the engine's not running, it's not getting hotter.
Old Jul 22, 2011 | 03:42 PM
Transmission: 700r
Re: Fail Safety?
The fan does run when the car is off.
Old Jul 22, 2011 | 03:55 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Fail Safety?
so you are saying, you drive the car 10 minutes so it gets hot, then turn it off. The fan is not currently running correct? then you put the key back in "run", engine still hot, no cranking, and the fan starts? thats normal.
Old Jul 22, 2011 | 04:54 PM
Transmission: 700r
Re: Fail Safety?
Ok I couldnt remember if that was normal or not. Been a while since I drove the car. Thanks
Buickstaged
Interior Parts Wanted
Oct 4, 2015 11:49 AM
racereese
Oct 3, 2015 03:46 PM
6998poncho
Sep 25, 2015 02:56 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
