A/c Problems
Old Aug 6, 2011 | 01:05 AM
Cwaterboy1's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI
A/c Problems
I have a 1991 Firebird. The A/C would not a hold a full charge for more than a day. I decided to replace the R12 with R134a components thinking any leaks might be fixed. I changed out the compressor, dryer, hoses and orphice tube with new ones. Took it to a shop today and they pulled a vacuum on the system and it held tight so they charged the system. It was working well for not even 12 hours and the clutch started engaging every few seconds and the air was no longer as cold. I believe this is an indication the freon is low.
How can you tell if the evaparator is leaking? Would a vacuum determine a leak if there was one in the evaporator. Also would this be the case for the condensor as well?
Any ideas?
Old Aug 6, 2011 | 01:08 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: A/c Problems
Did you add the oil treatment can? Is it blowing good air? Just not cold?
Old Aug 6, 2011 | 01:27 AM
Cwaterboy1's Avatar
Engine: 5.7 TPI
Re: A/c Problems
Yes I did add the oil as recommended. It was blowing good cold air and throughout the day it decreased in coldness and the clutch began to constantly engage.
I figured with a leak that large it would not hold a vacuum.
Old Aug 6, 2011 | 06:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: A/c Problems
Get the shop to use a 'sniffer' or have them add dye so that the leak can be seen with a UV light. You might also consider the condenser as the leak source.
JamesC
Old Aug 6, 2011 | 11:11 AM
Cwaterboy1's Avatar
Engine: 5.7 TPI
Re: A/c Problems
Just got back from the shop. The compressor seals for the hoses that came with the new compressor were not thick enough. When newly installed the thinner seals were good enough for the vacuum but once high pressure and heat was a factor the seals gave way causing a good size leak. Replaced seals with thicker ones and it seems to be fine for now, no leaks detected.
my86bird
Oct 23, 2015 12:20 PM
greenyone
Sep 2, 2015 03:39 PM
greenyone
Aug 29, 2015 11:08 AM
BikeFarm
Aug 11, 2015 11:35 PM
