pegged temp gauge
Old Aug 11, 2011 | 06:15 PM
huskybruiserjr's Avatar
Car: 1989 RS
Engine: 2.8
Transmission: auto
pegged temp gauge
just got my 89 camaro last night
from start up the gauge is pegged past normal temp range
gauge bad?
Old Aug 11, 2011 | 06:30 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: pegged temp gauge
Probably wire to sending unit is grounded somewhere - should be a green wire that runs to a sender on driver side head between #1 and #3 spark plugs - the sender will have a single male spade connector on it, and wire a single female spade connector.
Old Aug 12, 2011 | 11:07 AM
Car: 1989 RS
Engine: 2.8
Transmission: auto
even on a 2.8?
Old Aug 12, 2011 | 02:03 PM
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
Originally Posted by huskybruiserjr
even on a 2.8?
First rule out the gauge isnt stuck and take the dash out and move it down manually.
Old Aug 12, 2011 | 04:10 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
And by 'take the dash out', it's meant as take the trim bezel and lens off the instrument cluster, not literally, 'take the entire dash out of the car'.
Old Aug 12, 2011 | 05:05 PM
Axle/Gears: Stock
This.
Old Aug 12, 2011 | 05:06 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
If it goes back down when you turn off the car though, it's not stuck but probably grounded as mentioned. Same on any engine, they all use the same type sender, just in slightly different locations
Old Aug 12, 2011 | 11:11 PM
Car: 1989 RS
Engine: 2.8
Transmission: auto
nope it doesnt move when the car is off or on but ill take it out tomorrow after work
Old Aug 12, 2011 | 11:31 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
on the 2.8s the sending unit it right behind the ac compresser by the driver side valve cover
Bubbajones_ya
Jul 6, 2024 08:32 PM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
codeysabatini
Sep 20, 2015 11:36 AM
corey8084
Sep 17, 2015 02:56 PM
