Help, both fans dead!
Old Aug 13, 2011 | 01:17 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Just got home from driving the car and heard the coolent boiling. The temp guage was at 240*. Both of the electric fans were off. I have the passenger side fan working off a toggle and eliminated the switch it used to use in the passenger head. The second computer controlled fan, I have setup to come on at 175* and shut off at 165*. Is there a power relay to both fans and if so where is its location in a 89 Formula?
Old Aug 13, 2011 | 02:42 PM
Farmvillian's Avatar
Engine: 350 crate
Transmission: THM700-R4
Re: Help, both fans dead!
Im not sure of one running both fans. Umm I am assuming you checked your fuses. But the relay i am currently working with is oval and above the C100 on the drivers side firewall of the engine compartment. I hope this helps.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
92projectcamaro
Sep 29, 2015 07:07 PM
raymondandretti
Sep 27, 2015 06:43 PM
