Very Hot Compressor
Old Aug 20, 2011 | 09:51 AM
joeyspagz's Avatar
Car: 88 Firebird Trans Am
Engine: 305 tpi
Transmission: 700r4 shift kit
Axle/Gears: Posi
Very Hot Compressor
i just fixed all my leaks on my system, filled it with freon and o ring conditioner/oil...it didnt get cold so i felt my compressor and i burnt my hand off, it was so hot is this normal??
Old Aug 20, 2011 | 08:23 PM
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
Re: Very Hot Compressor
Sounds like you overcharged it. Get some gauges and check pressures, but im almost 100% positive you overcharged.
Old Aug 20, 2011 | 08:44 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
I agree with SS. With an overcharged system you will be over working the compressor by making it have to pump so much fluid. It should basically be warm enough to touch but not so hot you burn yourself. Also, re-check your lines and make sure you did fix all your leaks because no fluid will also cause your compressor to run hot as the fluid also cools it.
Old Aug 21, 2011 | 05:45 PM
joeyspagz's Avatar
Engine: 305 tpi
Axle/Gears: Posi
Ok thanks guys ill check the pressure
jrdturbo
Mar 31, 2016 02:58 PM
Thaney9
Oct 24, 2015 07:26 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
ironbmt
Sep 27, 2015 06:00 AM
