question about AC
Old Aug 22, 2011 | 10:24 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
question about AC
I recently replaced my engine and when I did I had the AC taken out the compressor and lines . The interior controls were left untouched. Now when my car is on there is a hissing noise from the AC as if it is on. My question is does anybody know what this is and how to get rid of it?
Old Aug 23, 2011 | 06:42 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: question about AC
Sounds like a vac leak. If so, air should be coming from the defrost ducts only.
JamesC
Old Aug 23, 2011 | 09:26 PM
Engine: 383 stroker
do you know how I can fix it?
Old Aug 24, 2011 | 06:13 AM
JamesC's Avatar
If the hissing is directly behind the HVAC, you probably need Valve Vac Sel GM part # 16032395.
There are some 'fix' suggestions in the link below:
https://www.thirdgen.org/forums/inte...ctor-disc.html
JamesC
Old Aug 24, 2011 | 10:20 PM
Engine: 383 stroker
thanks for the info
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
