coolant leak
Old Sep 17, 2011 | 05:07 PM
Firebird1990's Avatar
Car: 1987 Trans Am,1989 GTA
Engine: 5.0 Tuned Port Injection, 5.7 tpi
Transmission: 700r4, 700r4
Axle/Gears: 2:73 Posi, 3:27 Borg Warner 9 Bolt
coolant leak
Have a coolant leak have only been able to trace it too coming off the driverside motor mount nothing above it is leaking though is there a freeze plug on the other side of the driver side motor mount ? Engine is a 305 tpi btw.
Old Sep 18, 2011 | 02:25 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: coolant leak
there is a freeze plug directly behind where the clam shell mounts to the block.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
aaron7
Sep 30, 2015 09:15 AM
