Overheating at idle
Old Sep 9, 2011 | 08:53 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Overheating at idle
Im new here but i have some questions. I have a 92 firebird tbi stock. i have a new radiator and a manual fan switch on the dash. unless im moving fast my car overheats. what should i do?
Old Sep 10, 2011 | 12:12 PM
chrisfrerick's Avatar
Re: Overheating at idle
make sure both fans are working amd check for leaks. I had similar problem with no external leaks. after a few weeks coolant started to disappear from radiator. i had a cylinder leak down test preformed and two cylinders were leaking so I replaced head gasket.
Old Sep 10, 2011 | 01:19 PM
Car: 1984 T/A
Engine: LQ4
I have a single fan. There are no leaks too. Idk what it could be
Old Sep 10, 2011 | 04:55 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Won't cool unless air can get through the radiator. Check for leaves/junk blocking radiator front or between AC condenser and radiator. Also how fast are the fans turning?
Old Sep 11, 2011 | 05:33 PM
Car: 1984 T/A
Engine: LQ4
There is nothing blocked but i will double check. I have a single fan. Traffic just makes things worse since im always in the NJ/NY area....
Old Sep 11, 2011 | 05:50 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I've just got the single fan and it works when it's over 100 degrees here. Fan needs to be turning strongly to work well enough too cool properly
Old Sep 11, 2011 | 07:46 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Is the fan shroud intact, top and bottom? Needed to ensure air is pulled across the whole rad core, and doesn't recirculate around the sides of the fan.
Old Sep 11, 2011 | 08:11 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Is it actually overheating, or is the temp guage just high?
Overheating = actually boiling over. If it's not boiling over, then it's not overheating. Normal temps would be 220 - 240. If the guage is reading higher, but it's not actually boiling over, then replace the temp guage sender between #1 and #3 spark plug on driver head.
Old Sep 11, 2011 | 09:12 PM
Car: 1984 T/A
Engine: LQ4
It boils over. i was stranded for 6 hours 3 blocks from the entrance to the holland tunnel. what a mess
Old Sep 12, 2011 | 08:12 AM
torque_is_good's Avatar
flush your entire system, purchase an aftermarket fan and verify that the fan does work.
Old Sep 12, 2011 | 05:02 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
since it cools ok at higher speeds,does sound like
something wrong with the fan-with the fan running,see
if piece of paper or other light material will suck up to
the front of the radiator or A/C condenser and hold in
place-if it does the fan is working well enough-if not
fan may be wired backwards and trying to blow air
forwards which it will do quite poorly as the blades are
curved the wrong way running in reverse.
If its not the original type fan,could be running
backwards or have the blade on wrong causing it blow
poorly..
Old Sep 13, 2011 | 08:16 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Ha yeah check the basics! I got bitten by this just today - boiled it badly in about 5km. Wire fell off my temp sender, used by my homebrew fan controller. No fans running, and I didn't notice in time...
Old Sep 14, 2011 | 04:35 AM
oif0709's Avatar
From: http://www.facebook.com/ThirdGenCamaroFirebird
Car: 1987 Camaro Z28
Check your thermostat to. Idk why no one has mentioned that yet.
Old Sep 14, 2011 | 08:30 AM
it doesn't overheat when he's moving. If it were a stuck thermo then it wouldn't matter how the air is introduced be it via a fan or driving over 35 mph
Old Sep 14, 2011 | 09:32 AM
rsmith085's Avatar
Car: '88 Camaro
Engine: L03 TBI
Transmission: WC T-5
Axle/Gears: 7.625 10 bolt stock 3.08's
If your car still has the A/C condenser in place it could be clogged with bugs/grass and other junk that shouldn't be there. If it is that will create a restriction and prevent the fan from pulling enough air across the radiator. Mine was and was causing high head pressure on the A/C. Get a can of coil cleaner from Home Depot for 5 bucks and it works wonders to clean old radiators/condensers. I did and it made my A/C blow 10 degrees cooler! Also could not be enough fan or a weak motor. I swaped the Ford 2 speed fan in mine over the weekend and it cools way better than the stock one could ever dream of. Also check your air dam to make sure it's still there and in one piece.
Old Sep 14, 2011 | 10:27 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Since it cools OK while moving, the radiator is flowing air through it good enough to cool. Definitely sounds like a weak fan issue
Old Sep 14, 2011 | 11:35 AM
Car: 1984 T/A
Engine: LQ4
Thanks for the responses. Im gonna try and swap the fan this weekend.
Old Sep 14, 2011 | 11:51 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
You can sometimes find good ones at the JY or you can get new replacement motors at most parts stores if you don't want to replace the whole thing. Have fun!
Old Sep 14, 2011 | 12:37 PM
oif0709's Avatar
I no what your saying but everytime I have had a t-stat get stuck on me it always starts getting hotter when I idle vs driving.
Old Sep 14, 2011 | 01:23 PM
JohnRich88SC's Avatar
Car: 1988 Camaro
Engine: 2.8L V6
Transmission: Auto/OD
Axle/Gears: Stock
Is the temp sensor on drivers head on the V6 as well?
Old Sep 14, 2011 | 02:47 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
If you mean the sender for the temp gauge it's on the driver side near the front corner. More info on the V6 board
Old Sep 14, 2011 | 03:44 PM
in the state where we both live we are extra sensitive to the cooling system in our vehicles. I just put a hayden adjustable fan switch in and I like it.
I'm with you on replacing the thermo, they are cheap enough so why not.
Old Sep 14, 2011 | 10:08 PM
Car: 1984 T/A
Engine: LQ4
Would any of these fans work?
http://www.amazon.com/Derale-16934-H...d=O4UPSC4VOPKJ
http://www.amazon.com/PROCOMP-ELECTR...d=O4UPSC4VOPKJ
http://www.amazon.com/PROCOMP-DUAL-E...d=O4UPSC4VOPKJ
Old Sep 16, 2011 | 07:56 PM
Car: 1984 T/A
Engine: LQ4
poorly..
I turned the engine on and first checked to see where the air was blowing. There seemed to be a buildup of hot air in front of the radiator. to double check i ran the fan (with the engine off) and put a piece of paper between the fan and the engine. The fan sucked it in towards the radiator. Im kinda new to all this, how do i change the direction of the fan. will that solve the problem?
Old Sep 16, 2011 | 08:35 PM
rsmith085's Avatar
Car: '88 Camaro
Engine: L03 TBI
If it is blowing the paper towards the radiator when you put it in between the radiator and fan instead of sucking it into the fan it's def. backwards somewhere along the line. Check the wiring to make sure no one has replaced the connector and got the wiring backwards. On mine the solid black wire is ground and the black with red stripe is positive. If the wiring checks out more than likely someone replaced the fan motor and installed the blades backwards. In that case remove the fan(four 13mm bolts two top and two bottom) and there should be some sort of a clip holding the blades onto the motor shaft. Remove the clip, flip the blades around and put everything back together.
Old Sep 17, 2011 | 03:51 PM
Car: 1984 T/A
Engine: LQ4
I removed the fan to check out the situation. it seems someone had previously wired in the fan. about 10in from the plug to the fan there was electrical tape where the connections were made. i just swapped them, and the fan roared to life. its blowing real nice. I put paper in front of the radiator and it sucked it in. i think it should be good for now. we will see what happens when i take out for a long drive. Thanks to everyone for the help.
Old Sep 17, 2011 | 11:44 PM
Car: 1984 T/A
Engine: LQ4
now tht overheating is not an issue what temp should the engine be at? It stays right around 130 with the fan on.
Old Sep 18, 2011 | 12:13 AM
affliction1's Avatar
Car: 89 chevy camaro rs
sounds like thermostat is stuck open
Old Sep 18, 2011 | 02:23 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
stock fan switch turns the fan on at about 230. so 230-240 is normal stock running temps. did you mean 230 instead of 130?
Old Sep 18, 2011 | 03:46 PM
Car: 1984 T/A
Engine: LQ4
no i have a manual switch for my fan. and the engine runs at about 130. i dont turn the fan on anymore because it runs so cool.
Old Sep 18, 2011 | 04:17 PM
travis401's Avatar
Car: 91 Camaro RS
running too cool can be just as bad as overheating. it does sound like you have a tstat thats stuck or may not even have one at all. either way, you should get a good working tstat in there
Old Sep 18, 2011 | 04:24 PM
rsmith085's Avatar
Car: '88 Camaro
Engine: L03 TBI
I run a 180 degree stat in mine. Sounds like yours is stuck open or not there. 130 is way to low, in my opinion 200 is ideal. Being a 92 should have the wiring in place to run a fan switch if so get a Autozone SW510 switch for a GNX. They turn on at 210 and off at 185
junior419
Apr 7, 2025 11:35 AM
Bubbajones_ya
Jul 6, 2024 08:32 PM
Grant2k
Apr 4, 2016 08:21 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
