Overheating - Coolant Temp Sensor?
Old Sep 27, 2011 | 12:48 PM
mdelancy91's Avatar
Car: '92 Camaro Z28 25th A/E
Engine: 350ci 5.7L TPI
Hey all,
So after I did a full tune on my '92 Z28 5.7L (plugs, wires, cap, rotor, O2 sensor, ICM), it ran like a champ.
Two days later I was headed to work and noticed a harsh idle at red lights (w/ A/C on). About half way there the temp gauge started creeping up from ~220. I pulled into a parking lot and shut her down before it red lined.
When I tuned it up I made sure to take note if the fan worked, and it did. Normally I could hear it from inside the cabin (kinda clicking sound), but didn't notice it yesterday - couldn't hear it over the A/C whistle.
I let the car sit for about an hour with the key in the ON position - fan was running, had the A/C on "fan" too. Temp started going down as I expected it to.
I ended up leaving the car there for a few hours, walked home, and went back to it 6-7hrs later. Checked up under the hood before restarting it, and the antifreeze reservoir (which I topped off during tune up) was bone dry. Radiator was still full though. Filled up the reservoir and drove it home. No overheating, but it was night time in the rain so...
Could this be a bad coolant sensor? I know the fan works as it should so I don't think it has to do with that...
Old Sep 27, 2011 | 02:16 PM
torque_is_good's Avatar
Re: Overheating - Coolant Temp Sensor?
Originally Posted by mdelancy91
Hey all,
that is what you need to diagnose. Where is the coolant going?
Old Sep 27, 2011 | 02:21 PM
mdelancy91's Avatar
This is what I don't understand. The thing was full after I tuned it up. I always check my driveway, and occasionally check where I've parked when out to see if I notice any leaks (a little paranoid with a 20yr old car) and never saw a single stain or drop.
Even today, after I drove it home last night and let it sit, the reservoir was full...
I'm stumped.
Old Sep 28, 2011 | 08:27 AM
I'm stumped.
if coolant does not continue to disappear then perhaps your sytem was not full and it just pulled in the coolant from the bottle and now it's full. Only time will tell
do you have your air dam underneath? If not, you'd best get one
If you were anywhere near sarasota i'd say drive over and I'd show you the Hayden fan controller I put in and it's adjustable
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
corey8084
Sep 17, 2015 02:56 PM
m00n420
Sep 11, 2015 02:39 PM
FormulasOnly
Sep 10, 2015 09:07 PM
