Limp mode due to fan
Old Mar 14, 2011 | 01:58 PM
xsupermann69x's Avatar
Car: 1991 Chevy Camaro RS
Engine: V6 3.1L
Transmission: automatic
Alight here's the deal randomly my car has a mind of it's own but here's what happens. My car will go into a limp mode once the car gets hot enough for the fan to kick on and continues to kick on example 5oclock traffic n stop lights. Limp mode meaning it will start sputterig an not excellerate. And then it will stop and be fine again. What could it be? Fan relay? The fan turn on switch the temp sender? Ecu? What anyone else have the problem? Any input would be awesome.
Old Mar 14, 2011 | 03:12 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Limp mode due to fan
Is there a coolant temp sensor in the intake right by/at/on the thermostat housing? Some V8 cars have one, tells the computer coolant temps and computer changes tuning accordingly - might be bad. If like a V8 car, would have a black wire and yellow wire to it.
Old Mar 14, 2011 | 06:03 PM
Engine: V6 3.1L
alright i will try that any other suggestions?
Old Mar 14, 2011 | 06:27 PM
Twin_Turbo's Avatar
You do realize that in limp mode the fan is always on so it's probably limp mode triggering the fan, find out why it goes into limp mode.
Old Mar 14, 2011 | 06:43 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
I have a bad ecm, because of the ground so the fan is ALWAYS ON, bypasses... any good fix for cheap?
Old Mar 15, 2011 | 01:07 AM
Engine: V6 3.1L
no the fan comes on then eventually it will go into limp mode. then start running fine and the fan doesnt necessary kick back on for it to start being in limp mode again
Old Sep 20, 2011 | 05:21 AM
koolmatic's Avatar
yo dude. i had to register now coz i have the same problem with my car. i own a conquest 4age 20valve. did you solve your problem yet
Old Sep 29, 2011 | 01:46 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
okay so i had the same problem and had to get a piggyback because my PROM was coming loose from the ECM and making it limp..check your PROM and make sure its in the ECM good..
heres what i did:
unplug the battery..open the ecm..take the prom out and re-set it nice and firm into its slots and see if it happens again..
what happens is..over time they just get loose and the piggy back tightens everything up..
this is the one i used
http://www.moates.net/g1-memory-adap....html?cPath=64
might be different cuz you have a 91 but im not sure..
Veaceonee
Sep 29, 2016 08:15 PM
327IROC85
Sep 23, 2015 12:11 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
gta892000
Sep 16, 2015 12:37 AM
scottmoyer
Sep 7, 2015 07:06 PM
