NEW $78 ALL ALUMINUM RADIATOR!!!!
Old Oct 4, 2011 | 10:27 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Im close to purchasing this radiator for $78. But its a 1 row. Should I buy it? http://www.shepherdautoparts.com/all...7l_v8_350.html
Part Specifications:
Core Size (in) approx: ALUM 26-1/4 x 17-3/8 x 1-1/4
1 ROW
Tank: ALUMINUM
Weight: 11
Part Details
5.7L V8 ALL ALUMINUM - All Transmission.
Old Oct 5, 2011 | 10:33 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: NEW $78 ALL ALUMINUM RADIATOR!!!!
single row aluminum would probably cool the same as a normal stock one. if you're going the performance route, it may be worthwhile to step up to something bigger.
Old Oct 5, 2011 | 10:58 AM
I don't race much. None the less drive the Camaro everyday. My biggest concern is the 100+ degree summers. Would it be better to have my stock 3 row taken apart, cleaned out, re-soldered and re-installed??
Old Oct 5, 2011 | 01:19 PM
Goosehead's Avatar
if you take aluminum, you should go bigger anyway. An aluminum radiator cools a bit less good then a stock radiator of the same size.
Old Oct 5, 2011 | 09:19 PM
Seems like a gamble. I can either buy this 1 row aluminum radiator, or I can take my OEM 3 row radiator and have it taken apart and cleaned out for $30. What would you do if you where in my situation? New 1 row, or service my OEM radiator?
Old Oct 23, 2011 | 11:55 AM
onemanrace's Avatar
Car: 1988 Camaro IROC-Z
I'd say service the OEM one, unless the part you're going to fit is an improvement. Which from the sounds of it, it's a 50/50.
I'm in a similar boat (cracked tanks), and I'll be going with a 2 row ally replacement.
Old Oct 23, 2011 | 12:25 PM
I already junked the oem radiator and bought a $220 all aluminum radiator (Champion cc951). 3 row.
Old Oct 23, 2011 | 02:13 PM
onemanrace's Avatar
More or less the solution I've arrived at.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
jrdturbo
Mar 31, 2016 02:58 PM
lanceflame44
Sep 25, 2015 12:28 PM
