fan shroud for flex fan
Old Oct 5, 2011 | 10:48 AM
mcooksey's Avatar
I have an 86 Iroc z camaro. Someone else has stuck in a carb 350 with centerbolt heads. The original electric fan was not working, so I bought an 18" flex fan. I like it, but I was wanting to buy a fan shroud for it. Does anyone know if the trans-dapt 9454 fan shroud from summit racing will work? It says it's universal and will work with fans up to 20 inch. Will I still be able to close my hood? Thanks.
Old Oct 6, 2011 | 10:59 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: fan shroud for flex fan
i'd try to find a stock '82-85 camaro shroud-that
aftermarket"universal"shroud might not work well with
the leaned back f-body radiator.
Strangly,i've noticed some non-AC early thirdgens with
belt drive fan that did not have a full shroud,but some
non-AC do have a full shroud.
I saw a non-AC '83 CFI z28 that only had a
"finger guard" partial fan shroud,did not notice what fan
type was used-might have only had an "old skool"1950s
style rigid steel 4 blade fan
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
mfp189
Sep 27, 2015 09:25 AM
