Water cooling device I don't recognize next to the engine.
Old Oct 7, 2011 | 12:44 AM
firebirdgangsta's Avatar
This may be a stupid question so sorry. I just bought a 1988 bird with a 2.8 liter and I just had it towed to my house. I just now noticed a device mounted next to the passenger's side of the engine with a few short rubber hoses (they look like water lines about 2 or 3 inches long) sticking out of the top of it. I thought it was part of the heating system but it didn't seem to really connect to anything. I'm wondering what this thing is. Maybe a hose junction of some sort?? I'm probably just dumb and not getting it but I need to know what it is so I don't end up running it and then find out it's some vital cooling component that some idiot screwed with. It may just still be bolted on and not even be hooked to anything. It'd be awesome if somebody could tell me what this thing could be so I don't go and accidentally kill this amazing car. Thanks.
Old Oct 7, 2011 | 12:46 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Water cooling device I don't recognize next to the engine.
Can you post a picture?
Old Oct 7, 2011 | 12:52 AM
I would but unfortunately I don't have a functioning camera at the moment... o.o I'll try to put one up as soon as I can.
Old Oct 7, 2011 | 01:01 AM
Impaqt's Avatar
Car: 88 Iroc-Z Convertible
Sounds like the Vapor cannister
Emmisions piece.
Old Oct 7, 2011 | 01:04 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Oh and it is very important. Used for emissions, vapor fuel lines, air vac. Get a book 82-92 camaro Chilton,Chevrolet, Haynes > manuals! Will show you and tell you exactly what it does.
Old Oct 7, 2011 | 01:31 AM
That would make sense. But I'm not sure, I forgot to mention that the hoses were like 1" in diameter. And isn't the vapor canister usually closer to the bumper? (Meaning not so close to the engine. if it was it sounds like it could become explosive from heat) I know that on my '83 bird it's up near the bumper on the driver's side next to the horns (It's just sitting there btw. Obviously it's not gonna be used on a 350). Oh yeah and stupid me misplaced my third gen Haynes manual. Grrr...
Old Oct 7, 2011 | 01:49 AM
Engine: MPFI
Yes it is closer to the front. Sounds like the cooling device, hoses connect to it. Did you say it was on the driver side or passenger side?
Old Oct 7, 2011 | 05:28 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Probably the heater divert valve. It shuts off the water to the heater core when you have the AC on. Controlled by a vacuum line from the HVAC control head inside the car.
Old Oct 7, 2011 | 11:53 AM
Thank you! That has to be it. What's annoying me now is why it's just sitting there with nothing hooked to it.....
Old Oct 7, 2011 | 12:01 PM
Impaqt's Avatar
It was probably leaking so they bypassed it.
Old Oct 7, 2011 | 12:50 PM
That's possible. I hope that's what happened because I don't want to have to deal with an open cooling system. Not the most complicated repair but still annoying.
toronto formula
Nov 10, 2015 06:17 AM
theurge
Aug 21, 2015 12:46 PM
Bryan F
Aug 18, 2015 02:28 PM
sreZ28
Aug 14, 2015 07:48 PM
