AC condenser question
Old Oct 15, 2011 | 02:58 PM
tmsumner1's Avatar
Car: 87 Iroc Z-28
Engine: 388 SBC
Transmission: 700R4 to modded TH400
Axle/Gears: 7.5" 4.10 to 9" 3.70
Will a AC condenser from a serpentine belt system work on a V-belt setup? Let's here it gurus. hahaha
Old Oct 15, 2011 | 03:24 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: AC condenser question
I'm guessing you meant compressor since the condenser is sitting in front of the radiator and doesn't care what kind of an engine is in there
Old Oct 15, 2011 | 03:28 PM
tmsumner1's Avatar
Car: 87 Iroc Z-28
Engine: 388 SBC
No I am talking about the condenser. Wondering since the compressor spins the opposite way if it would make a difference in the condenser.
Old Oct 15, 2011 | 03:42 PM
tmsumner1's Avatar
Car: 87 Iroc Z-28
Engine: 388 SBC
Serpintene compressor will spin the opposite direction than the v-belt. will the fluid be going through the condenser differently? Just clarifying might have been more confusing though
Old Oct 15, 2011 | 03:53 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Compressor runs the same direction either with v belt or serpentine. It's the water pump that spins backwards on the serp.
Condenser is the same for both setups.
Old Oct 15, 2011 | 04:25 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Old Oct 16, 2011 | 09:09 AM
tmsumner1's Avatar
Car: 87 Iroc Z-28
Engine: 388 SBC
I knew about the water pump spinning the opposite direction. Is that the only accesory that spins opposite in a serpentine system?
Old Oct 16, 2011 | 10:15 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Street Lethal
Aug 13, 2015 08:28 PM
Street Lethal
Aug 12, 2015 11:33 AM
