Need clip that holds vacuum selector switch together
My heat/ac selector was leaking vacuum and when I took it apart I noticed one of the "tips" were broken on the clip that goes through the middle of the parts and holds the assembly together. I bought what I thought would be a new switch but turns out it is only the back piece that accepts the vacuum hoses, the rubber seal that has the vacuum slots cut in it, and the front plastic piece..... NO CLIP! Anyone know where I can get one or even a part number for this?
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Need clip that holds vacuum selector switch together
I've got some good spare parts I can get you for cheap. PM or email me your email for pics and other info
Henry
Henry
Henry,
I really appreciate that offer and I may take you up on it if my "fix" doesn't work. Had a brain storm and have an idea, if it doesn't work out I will be in touch!
Thanks!
Thanks!
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Aug 17, 2015 02:00 PM
