Heater vents only work out the defroster
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Ok so I was looking uP info on here an found that the heater vents work off vacuum I found the two vac lines that I broke how would I replace those an where do I hook them up to a 355 carb sbc I know one is full vac an the other is ac I think but I dont have ac ????
Re: Heater vents only work out the defroster
One is a vacuum source (intake) and the other is the heater bypass valve line. Cap/plug the bypass and hook the other one to any vacuum port on the intake.
Engine: LR4 4.8
yea i got it to work out the vents today wooohooo i hooked one line up to the full vaccum port on the carb an blocked the other one off
AkDrifted
Aug 17, 2015 07:45 PM
mustangman65_79
Aug 11, 2015 03:17 PM
