Coolant leak
Old Nov 20, 2011 | 07:28 AM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Coolant leak
I've got a coolant leak that seems to be getting worse. Problem is, I can't find where it's coming from. The puddle is under the front of the transmission. I can see where it runs down the bottom transmission cover. It doesn't seem to be coming from a head, intake manifold or a freeze plug. Where else could it be coming from? I've used mirrors and one of those cameral on a stick things, but I can't seem to find it.
1987 IROC
5.7
700r4
Steve
Old Nov 26, 2011 | 07:48 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Coolant leak
Cracked block inside bellhousing?
Old Nov 26, 2011 | 10:37 PM
NCGuy68's Avatar
Car: A lousy LS1 car
Engine: 347 Cu. In.
Transmission: Which One?
Re: Coolant leak
......or more likely a leaking freeze plug on the back of the block.
This may sound redundant but clean the entire back of the motor including the intake, heads, block, bellhousing, etc the best you can. You might even have to use a power-washer to reach places your hands can't get to. On a COLD motor pressurize the cooling system (many parts stores rent a kit to do just this) and look again. Coolant leaks can be a real pain to find so take your time. Remember too, that anti-freeze is 'thinner' then straight water and will find a place to leak that water will not.
Worst case is to remove the tranny and bellhousing and have a look.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
aaron7
Sep 30, 2015 09:15 AM
