Coolant sending unit location??
Hello, where would my coolant sending unit be?? This should be attached to the block, Correct? I can not find any extra information in my Haynes Manual..
Just to clarify, the thing that hooks to my temp gauge..
305 v8 tpi..
305 v8 tpi..
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Coolant sending unit location??
the temp gauge sender is in the cylinder head between 1 and 3 cylinder
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
^ he's correct, and the other one that controls your fans is on the other head between cylinders 6 and 8
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
tpi main fan is computer controlled the secondary fan might run off the fan switch on the passanger head. the ecm coolant sensor is on the front of the intake.
Ghettobird52
Jul 5, 2024 11:18 PM
ambainb
Apr 25, 2016 09:21 PM
Glowsock
Aug 26, 2015 12:28 AM
