Coolant tank overflowing
Old Dec 15, 2011 | 01:17 AM
1991 Z28's Avatar
Car: 1991 Camaro Z28
Axle/Gears: LS1 3.23
I have a 91 Z28 with a 5.0 TPI. When I was warming up my car this morning, i noticed that the coolant overflow tank was filing up and overflowing out of the tank. The temp began to climb as well. I didn't notice any coolant leak around my water pump as I thought it was not circulating. Do you think my thermostat is not opening? I touched the top radiator hose and it wasn't hot even though my temp was well over 220 degrees. Any input will be appreciated. Thanks
Old Dec 15, 2011 | 10:23 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Coolant tank overflowing
Sounds like the radiator cap is not holding pressure. Get a new one
Old Dec 17, 2011 | 08:11 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
was the tank just filling up or was it bubbling?
Old Dec 17, 2011 | 11:19 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
could b cap or T-stat. worst case is head gasket.
Old Dec 18, 2011 | 09:28 AM
1991 Z28's Avatar
it was just filling up.....I hope everyone is right that it is just the thermostat or radiator cap.
Old Dec 18, 2011 | 06:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
if its just filling up, its probably the cap. Its cheap, give it a try
Old Dec 24, 2011 | 12:34 AM
amlv20's Avatar
Car: 1986 iroc-z
Engine: 5.0 tpi
Axle/Gears: stock.
if its a cap thats not holding pressure it would boil at a lower temp and the top hose would be hot, since the hose is staying cold the tstat is stuck shut.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
