intake manifold gasket and motor oil ?
Old Jan 18, 2012 | 09:21 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I was given a quote on replacing a intake manifold gasket because of a coolant leak.. My question is = Why did they add a oil change in the price and they also want to charge me for a jug of antifreeze . I replaced the gasket years ago and did not loose coolant.
Old Jan 19, 2012 | 11:30 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: intake manifold gasket and motor oil ?
you do have the coolant crossover on the intake so they'll have to drain off a little to make sure nothing pours into the oil or cylinders. oil change is just cheap insurance in case something does fall in (like coolant or debris)
Old Jan 19, 2012 | 05:22 PM
one92rs's Avatar
Car: SOLD!!!!!
they did it right then. i always change the oil when doing the intake gaskets. and even if i dont use the whole jug of antifreeze i still charge the whole jug.
Old Jan 19, 2012 | 09:02 PM
Engine: TBI,5.0
Thats kinda what I thought but wanted to make sure.I hope its not mandatory for them to do the oil change .I change my own oil and filter with Mobil 1 Synthetic and the taller Bosch filter.
Edit= I guess the hole point of changing the oil then and there is to keep the contaminants from cycling through the system.
Maybe they will let me supply/bring the oil and filter.
Old Jan 21, 2012 | 02:54 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
More than likely they will. Its always a good idea to change the oil if the intake comes off. Also a good idea to actually drain the coolant from the block so coolant doesn't pour into the block valley.
Old Jan 21, 2012 | 09:44 PM
Engine: TBI,5.0
The shop I'm going to has a very good reputation and I'm sure that my little problem is old hat for them and I'm sure there used to the customers asking about what "needs" to be done ,as opposed to asking exactly how there doing it. Oh well its my car and my money so I'm going to ask what the procedure entails.
Edit = Its not that I don't trust them, it is that I want know a few things for future reference.
Jake_92RS
Jan 28, 2020 10:37 PM
Navy8125
Aug 21, 2015 09:32 AM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
