Fan not turning on
Subscribe
Jan 26, 2012 | 08:15 PM
My engine is overheating especially when I have to park or drive slowly. Not at high speeds. I have a switch under the dashboard that is suppose to turn the fan on but it doesn't work anymore. I even tried replacing the switch...
Now I have no knowledge of how wiring and everything works....so could I get some advice on what could be wrong and where to start looking? Does this switch hook to the battery?
Reply 0
Jan 26, 2012 | 08:23 PM
Re: Fan not turning on
Try and follow the wires from the switch. There should be a power source and ground basically. If you flip the switch and get nothing, theres either a bad connection somewhere, bad fuse, or your fan motor is burnt up. Just check all your connections and make sure they're good.
Reply 0
Jan 26, 2012 | 09:01 PM
Quote: Try and follow the wires from the switch. There should be a power source and ground basically. If you flip the switch and get nothing, theres either a bad connection somewhere, bad fuse, or your fan motor is burnt up. Just check all your connections and make sure they're good.
Okay sounds easy enough.
Reply 0
Subscribe
