cooling fan not coming on
Old Jan 28, 2012 | 11:17 AM
cdaluisio's Avatar
i have an 89 iroc with 305 tbi just got running from previous owner who hacked wiring evrything works fine but cooling fans only comes on with a/c switch have changed ecm and temp sensor located on intake manifold and also changed fan relay dont know where to go from here help please
Old Jan 28, 2012 | 06:12 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: cooling fan not coming on
You have single or dual fans?
Old Jan 29, 2012 | 07:00 AM
cdaluisio's Avatar
i have single fan setup
Old Jan 29, 2012 | 11:14 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Since the fan comes on with AC, your relay and fan are good. The fan switch that actuates the relay at a certain temperature is located on the passenger side head between the last two spark plugs. Should have a green with white stripe wire going to the connector on it. The switch grounds the wire going to the relay and turns on the fan. The switches go bad often. Do a search on fan switch on the cooling board and you will find lots of info on here about testing and choices for different switches
Old Jan 29, 2012 | 06:36 PM
cdaluisio's Avatar
thanks found it everything works great
eightsixseven
Dec 16, 2024 01:50 PM
krisner89
Oct 10, 2015 06:03 AM
TheExaminer
Aug 26, 2015 04:59 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
Leggman1
Aug 6, 2015 04:15 AM
