hose routing heater delete a/c delete
Old Jan 30, 2012 | 08:44 AM
kreator33's Avatar
hi, im putting a tpi motor in my 86 t/a, i removed the heater,i removed the a/c,and im not passing the coolant through the throttle body,,so just to double check to be sure, is all i need,the 2 big main hoses from lower rad to pump,and upper rad to thermostat neck?? can i just plugg/delete the exits on the lower front of the intake manifold and everything else?
Old Jan 30, 2012 | 09:03 AM
kreator33's Avatar
Re: hose routing heater delete a/c delete
and also,what thermostat should i use?? remember,i have no heater,not gonna drive this car in winter,want performance only!
Old Jan 31, 2012 | 04:02 AM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Just plug up the ports on the manifold with an allen plug.
Since you have a TPI, you don't want to go any lower than 180 due to the computer and all it's fussiness.
Old Jan 31, 2012 | 08:21 AM
kreator33's Avatar
thanks,thats what il use
Old Jan 31, 2012 | 11:54 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
If you have iron block and heads you will b just fine with a 160 t-stat.
I have been running one in my aluminum headed 89 350(well bigger now) formula since 92 and its been just fine. Also use a cooler fan temp switch or chip that'll kick the fan on earlier..
Old Jan 31, 2012 | 12:05 PM
kreator33's Avatar
i have an iron block,aluminum heads,im gonna have a chip done so anything can be done at this point,
codeysabatini
Nov 10, 2015 04:07 PM
Formula8r89
Sep 22, 2015 04:24 PM
buckshot63
Sep 10, 2015 09:15 AM
Silver Spear
South East Region
Sep 8, 2015 12:06 PM
Silver Spear
South East Region
Sep 8, 2015 11:59 AM
