Could this cause overheating?
Old Jan 30, 2012 | 05:06 PM
Gsoleski's Avatar
Car: 1984 Z28
Engine: Vortec 350, hotcam
Put a new hose on this today because the old one was rotted and had holes all in it. The car overheated when I first got it so I replaced the thermostat, new coolant, and did an oil change and it has been fine for the last couple weeks. Now I replaced this hose and it overheats? It was around 230 degrees and there is a 190 thermo in it.The new hose is the one my fingers are on
Old Jan 30, 2012 | 09:04 PM
olveracm's Avatar
Car: 88 Firebird WS6 red
Engine: 305 TBI
Re: Could this cause overheating?
What is that hose for?
Old Jan 30, 2012 | 10:40 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Looks like thats a evap hose going to an evap solinoid. Others might know since I dont have that particular set-up.
Old Jan 30, 2012 | 10:57 PM
Gsoleski's Avatar
Car: 1984 Z28
Its the EVAP canister purge valve. The hose I put goes from this to the carb. I think I have a bigger problem because after 30 minutes I was finally able to get the car to turn over and it was about to stall if I didn't have the RPM's above 2000. Lots of smoke out the tail pipes and when I parked the car and shut it off the smoke continued to flow out
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
