TPI Cooling Flow?
Old Feb 10, 2012 | 05:45 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
TPI Cooling Flow?
What is the cooling flow direct of a TPI with the oil cooler?
Trying to rack my brain and figure out how I can rout it if I eliminate the heater control valve since I did away with the a/c... Problem is that metal pipe on the p/s has 3 ports
Old Feb 13, 2012 | 01:53 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: TPI Cooling Flow?
Short length of heater hose, correct sized bolt and a hose clamp.
Old Feb 13, 2012 | 06:28 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Direction of flow is FROM the heater core TO the oil cooler, then TO the rad.
If you want to bypass the diverter valve, run a single hose from the intake to the heater core inlet (might as well bypass the throttle heater if you haven't done so already). Then simply plug the metal pipe that sticks up from the right side frame rail (the one that used to go to the third port on the diverter valve that isn't there anymore).
Old Feb 13, 2012 | 09:07 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Use a hard metal tube (that bolts to the frame rail on pass side) from a non A/C car or a 85ish TPI car. They don't have the third port.
LT1Formula
20
Nov 14, 2015 12:02 AM
gta90
Sep 15, 2015 04:00 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
