Coolant hose cleanup/reroute... need some help...
Car: 85 Camaro Z28
Engine: 5.7 TPI
Hey fellas, last year I elimanated most of the hoses under the hood of the Camaro. One issue I am running into is that I used a rubber cap on the passengerside radiator nipple... looks like about a 5/8th in nipple. The issue is that the cap cracks and leaks after a month or two. What can I do to seal this nipple. Another thought was to run a heater hose from this port to the front of the intake manifold. The manifold port nipple was removed and a plug was installed but can easily be changed back over. The only issue I see with adding the hose is the routing as there are several bends and I cant find a molded hose to fit good in there. I would like to just permanently seal the nipple on the radiator but these damned caps keep breaking up. What can I do to remedy this? I thought about tapping the port and installing a plug, but as it is plastic, I am kinda iffy.... Is there any better alternative other than replacing the crap rubber cap every couple months?
5.7 TPI
5.7 TPI
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Coolant hose cleanup/reroute... need some help...
Isn't that nipple where the return from the heater core would normally be? I'm guessing you perhaps bypassed the heater core? Couldn't you run a hose from where the heater core feed came from after going through the engine to that nipple to return heated water to the radiator?
