Question about part
Old Feb 26, 2012 | 01:44 PM
JRambo's Avatar
Question about part
I need to know the name of this part and also where the other end of the cable in the picture goes. Had to fix a leaking problem by replacing hoses that connect to this piece but now other end of the long cable isn't connected to anything.
Old Feb 26, 2012 | 02:37 PM
Re: Question about part
Looks like your heater control valve.
The "cable" is actually a vacuum line; the control head in the dash routes vacuum to all the little doors that control air flow, and to that thing, to control whether hot water flows through the heater core.
I don't recall whether applying vac to it tells it to open it up, or tells it to close.
Old Mar 16, 2012 | 11:57 AM
JRambo's Avatar
But i need to know where the other end goes to. Right now it's not connected to anything.
Old Mar 19, 2012 | 07:09 AM
Other end of what?
Old Mar 19, 2012 | 09:40 AM
JRambo's Avatar
The vacuum line. The one end is connected to the top of the heater control valve and the other side is connected to nothing.
Old Mar 19, 2012 | 04:44 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
your heater control valve...
and to that thing,
Old Mar 19, 2012 | 08:19 PM
Look at the small harness that comes through the firewall right below the heater hoses. It's the complete assy for the HVAC, including both wires and vacuum lines. Should be easy enough to find it in there. There's 2 vac lines; one is purple, and is the "supply" line to the control head. The other is the one for the valve and is some other color (white IIRC).
redmaroz
Aug 16, 2015 11:40 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
reiderz iroc
Aug 13, 2015 04:57 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
