cooling fans
Old Feb 28, 2012 | 09:18 AM
bigcountry1979's Avatar
Car: 90 iroc z
Transmission: 4 speed with od
Axle/Gears: 323 ratio
cooling fans
Anyone know if I can hook my electric fans to a toogle switch on my 90 irocz 350"so I can run them fulltime? Would it cause any kind of inerferance with electronics?
Old Mar 5, 2012 | 03:42 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fan Plan
Yes you can on the fan.
On the fan relay there is a
dark green wire with a
White stripe.
Connect a wire to that point and run it to a switch in the cockpit.
Connect the other side of the switch to ground.
No interference.
Happy Racing!
I Didn’t Wreck, The Track Moved
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
