Ron Davis Radiator
Old Mar 9, 2012 | 07:00 AM
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
Ron Davis Radiator
Has anyone used one of Ron Davis Rad/Fan setup. If so how did you make out and are they worth the money.
http://www.rondavisradiators.com/radgallery.htm
Old Mar 9, 2012 | 08:11 AM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
Re: Ron Davis Radiator
I the use a Ron Davis Rad but the fan isn't. Built to spec, perfect quality, more than up to the task. Trully a hi-performance piece.Yes, worth the money,IMO.Name:  100_0958.jpg
Old Mar 9, 2012 | 06:07 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
I've seen quite a few in which the tranny cooler has split internally and ruined the trans by running water through it.
Old Mar 9, 2012 | 06:14 PM
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
92 BBC Z, your water pump looks awesome.
Where does your lower rad hoes hook up to?
Old Mar 13, 2012 | 10:36 AM
Beater79TA's Avatar
I'd be interested to hear more on this. I've had one for a while and this is the first I've heard of this concern with the tranny cooler.
Old Mar 14, 2012 | 02:10 PM
91 1LE's Avatar
Car: '91 1LE
My buddies used to work at a Cadillac dealership and they would install these radiators in the CTS-V's they would build. After at least 3 failures and a lack of support from Ron Davis they stopped using them.
Old Apr 1, 2012 | 12:50 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
You shouldn't use the cooler anyway. Use an aftermarket cooler in front of the condenser, Why try to cool a fluid with hot water?
sheachopper
Jul 31, 2019 11:27 AM
lanceflame44
Sep 25, 2015 12:28 PM
