coolant passage from one cylinder head to another
Old Mar 19, 2012 | 07:49 AM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
has anyone on here ever tried plumbing a -6 water line into the exhaust side of the head between 5/7 and 6/8? ive heard this helps with cooling of head in "hot" spot area.also evens out the whole cooling process too.
or has anyone with a single plane/ dual plane intake try plum a water line from the back of the intake near where the distributor is to the front thermostat passage? or even from the passanger side to driver side of the intake in the back?
just thinking out loud here, ive seen the intake mods like that before but i wonder if they actually help with anything...
Old Mar 19, 2012 | 08:40 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: coolant passage from one cylinder head to another
i was thinking about trying something like that. heres a water by-pass kit from jegs.
http://www.jegs.com/i/JEGS-Performan...51100/10002/-1 might be what your refering to?
1992 Trans Am
May 10, 2023 07:19 PM
Cornholio7979
Sep 20, 2018 02:31 AM
Chuck84TA
Jul 15, 2016 09:05 PM
NinjaNife
Aug 23, 2015 11:49 AM
