HELP- electric fan
Old Mar 30, 2012 | 09:40 PM
transam357's Avatar
Car: 1986 Pontiac Trans Am
Engine: 350 .40 over (357)
HELP- electric fan
alrite when i got my trans am it didnt have a fan hooked up and the wire on the electric connector in the radiator was cut. i'm guessing that was a thermostat and factory idk...any help on this plug in/wire and where it runs and what it does would be greatly appreciated
also, what would be a good choice for a fan, clutch fan or electrical?
Old Apr 1, 2012 | 12:30 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: HELP- electric fan
Electrical is the most modern. The past several years the hotrod guys are swearing by the two speed Ford Taurus fan. As soon as I find one I will be giving them a try. If the factory setup is FUBAR then run a power wire to a relay and get a good aftermarket fan and run it to a switch. Just get above 3500CFM and high amps.
Old Apr 20, 2012 | 10:38 PM
transam357's Avatar
cool thanks man im starting to wonder if this is even the stock radiator o well
sheachopper
Jul 31, 2019 11:27 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
