A/c & coolant sensor circuit problems1987
Old Apr 13, 2012 | 11:01 AM
ZBARON's Avatar
1987 Iroc z28 5.7 tpi. Had no cooling on car last fall and took to local chevy DEALER to get it fixed. Already had it switched to 134. They replaced the compressor and 35974 ac switch. Worked fine after this spring the compressor wont even engage. Any thoughts would be helpful when I take it back in for more service. Is the outside temp have anything to do with engagement since it has only gotten to 60 so far this year and if thats the case wont it engage anyway on the defrost setting?
Old Apr 13, 2012 | 02:29 PM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Re: A/c & coolant sensor circuit problems1987
Defrost shouldn't be affected unless you're trying to blow cold air.
Old Apr 13, 2012 | 04:28 PM
ZBARON's Avatar
Yes just trying to get the compressor to engage. I know on my pickup the compressor will cycle at 10 below when defrost is on. If all the freon leaked out over winter storage should the compressor run constantly or not engage at all?
Old Apr 13, 2012 | 06:27 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If all the refrigerant leaked out over winter storage should the compressor run constantly or not engage at all?
Not at all.
Old Apr 13, 2012 | 07:53 PM
ZBARON's Avatar
What I was thinking whatever happened to sightglasses at least you had a clue what was in system!
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
m00n420
Sep 11, 2015 02:39 PM
FormulasOnly
Sep 10, 2015 09:07 PM
Ironhead38
Sep 7, 2015 02:26 PM
